The MAC address of the specified neighbor changed.
Check the configuration of the transmitting router(s) on this interface. It is possible that multiple routers are configured with the same system ID on this VLAN - which is illegal. If the change in MAC address is legitimate, the adjacency needs to time out. To expedite this, remove the interface from this router and re-add it. Note that this may result in a temporary blackhole.
Warning
%vlanName%-%sysId% MAC address changed (%srcMac%)
| Name | Type |
| vlanName | VLAN |
| sysId | String |
| srcMac | srcMAC |
